Displays detailed information about the user.
| hex_user_name | Specifies the user name to display. The value is to be supplied as a colon separated string of hex octets. |
| user_name | Specifies the user name to display. The value is to be supplied in ASCII format. |
N/A.
The show snmpv3 user command displays the details of a user. If you do not specify a user name, the command will display details for all the users. The authentication and privacy passwords and keys will not be displayed.
The user entries in SNMPv3 are stored in the USMUserTable, so the entries are indexed by EngineID and user name.
The following command lists all user entries:
show snmpv3 user
The following is sample output from this command:
switch # sh snmpv3 user Engine-ID : 80:00:07:7c:03:00:04:96:27:b6:7b 'H' User Name : admin Security Name : admin Authentication : HMAC-MD5 Privacy : DES Storage Type : NonVolatile Row Status : Active Engine-ID : 80:00:07:7c:03:00:04:96:27:b6:7b 'H' User Name : initial Security Name : initial Authentication : No-Authentication Privacy : No-Privacy Storage Type : NonVolatile Row Status : Active Engine-ID : 80:00:07:7c:03:00:04:96:27:b6:7b 'H' User Name : initialmd5 Security Name : initialmd5 Authentication : HMAC-MD5 Privacy : No-Privacy Storage Type : NonVolatile Row Status : Active Engine-ID : 80:00:07:7c:03:00:04:96:27:b6:7b 'H' User Name : initialsha Security Name : initialsha Authentication : HMAC-SHA Privacy : No-Privacy Storage Type : NonVolatile Row Status : Active Engine-ID : 80:00:07:7c:03:00:04:96:27:b6:7b 'H' User Name : initialmd5Priv Security Name : initialmd5Priv Authentication : HMAC-MD5 Privacy : DES Storage Type : NonVolatile Row Status : Active Engine-ID : 80:00:07:7c:03:00:04:96:27:b6:7b 'H' User Name : initialshaPriv Security Name : initialshaPriv Authentication : HMAC-SHA Privacy : DES Storage Type : NonVolatile Row Status : Active Total num. of entries in usmUserTable : 6
The following command lists details for the specified user, testuser:
show snmpv3 user testuser
The hex_user_name parameter was added in ExtremeXOS 11.0.
