This command displays global configuration and run-time parameters for MSDP.
| vrname | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
N/A.
Use this command to verify the global configuration parameters of MSDP.
The following command displays global configuration and run-time parameters for MSDP:
Switch.2 # show msdp MSDP Enabled : No VR-Name : VR-Default Originator RP Addr : not configured SA Cache ageout time : 360 Store SA Cache : Yes SA Cache Server : not configured Export Local SAs : Yes Export SA filter : not configured Max Rejected Cache : not configured Encapsulate data : Yes Num of Rejected SAs : 0 Total Num of SAs : 0 Num of Local SAs : 0 AS Disp Format : Asdot
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
