Use this command to configure the time setting on a UPM timer.
| timer-name | Specifies the name of the UPM timer to be created. |
| month | Configures the month when the UPM timer is activated. |
| day | Configures the day when the UPM timer is activated. |
| year | Configures the year when the UPM timer is activated. |
| hour | Configures the hour when the UPM timer is activated. |
| min | Configures the minute when the UPM timer is activated. |
| secs | Configures the second when the UPM timer is activated. |
| seconds | Configures the UPM timer to be activated at every instance of the specified interval. |
N/A.
Use this command to when you know the exact time you want an event to execute. If you use this command without the every keyword, the timer is activated once at the specified time. The every keyword configures a periodic timer that is activated at every instance of the time specified in seconds.
When a switch configuration is saved or restored, the UPM timers are activated only at the predetermined timings that were originally configured with the start time.
The following example shows how to configure a timer, T1, that is activated every 10 seconds beginning at 1400 hours on October 16, 2006:
# configure upm timer "t1" at 10 16 2006 14 00 00 every 10
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
