Deletes an NTP key; it cannot be used for outgoing or incoming NTP sessions.
| keyid | Specifies the key ID as a value from 1 to 65534. |
| all | Deletes all keys. |
N/A.
N/A.
The following command deletes NTP key 5 on the switch:
delete ntp key 5
The following command deletes all NTP keys on the switch:
delete ntp key all
This command was first available in ExtremeXOS 12.7.
