Disables the use of the specified Universal Port profile on the switch.
| profile-name | Specifies the UPM profile to be disabled. |
A UPM profile is enabled by default.
The following command disables a UPM profile called sample_1 on the switch:
disable upm profile sample_1
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
