This command displays VLAN Authorization information for a port or list of ports.
| port | Show VLAN Authorization information for a specific set of ports. |
| port_list | Specifies the list of ports to show VLAN Authorization information for. |
If no parameters are specified, all VLAN Authorization configuration information is displayed.
None.
This example shows how to display VLAN Authorization configuration information for ports 1:1-3:
# show policy vlanauthorization port 1-3
VLAN Authorization Global Status: ENABLED
Admin Oper
Port Status Egress Egress VLAN ID
1 enabled untagged untagged none
2 enabled untagged untagged none
3 enabled untagged untagged none
This command was first available in ExtremeXOS 16.1.
