Assigns a tag to a VMAN.
| vman_name | Specifies a VMAN name. |
| tag | Specifies a value to use as the VMAN tag. The valid range is from 2 to 4094. |
N/A.
Every VMAN requires a unique tag.
You can specify a value that is currently used as an internal VLAN ID on another VLAN; it becomes the VLAN ID for the VLAN you specify, and a new VLAN ID is automatically assigned to the other untagged VLAN.
The following example assigns a tag of 120 to a VMAN named "accounting":
configure vman accounting tag 120
This command was first available in ExtremeXOS 11.0.
