Allows a port to be selected as an alternate or backup port.
| stpd_name | Specifies an STPD name on the switch. |
| port | Specifies a port. |
The default is disabled.
Use this command to revert to the default that allows a specified port to be elected to any STP port role.
The following command disables an active role on STDP s1, port 6:3:
configure stpd s1 ports active-role disable 6:3
This command was first available in ExtremeXOS 12.5.
