enable pim snooping
enable pim snooping {{vlan} name}
Description
Enables PIM snooping globally or on one or all VLANs.
Syntax Description
name Specifies a VLAN.
Default
Disabled.
Usage Guidelines
PIM snooping does not require PIM to be enabled. However, IGMP snooping must be disabled on VLANs that use PIM snooping. PIM snooping and MVR cannot be enabled simultaneously on a switch. PIM snooping should not be enabled on a VLAN that supports PIM-DM neighbors.
The following example enables PIM snooping on the default VLAN:
enable pim snooping default
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
