Defines how long a multicast source (S,G) is considered active after a packet is received from the source.
| ipv4 | Specifies the IPv4 address family. |
| ipv6 | Specifies the IPv6 address family. |
| interval | Specifies a source-active timer interval in seconds. The range is 90–300 seconds. |
210 seconds.
None.
The following example configures the interval to 180 seconds:
configure pim state-refresh timer source-active-timer 180
This command was first available in ExtremeXOS 12.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
