Displays static IGMP snooping entries.
| name | Specifies a VLAN name. |
| group | Displays static multicast groups. |
| router | Displays static router entries. |
None.
Use this command to display the IGMP snooping static groups or router ports configured on the specified VLAN. When no VLAN is specified, all the static groups or router ports are displayed.
The following command displays the IGMP snooping static groups configured on VLAN vlan101:
# show igmp snooping vlan101 static group VLAN vlan101 (4094) Group Port Flags 239.1.1.2 29 s- 239.1.1.2 30 s- 239.1.1.2 31 sa 239.1.1.2 32 s- 239.1.1.2 34 s- Total number of configured static IGMP groups = 5 Flags: (s) Static, (a) Active
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
