Configures the ESRP priority.
| esrpDomain | Specifies an ESRP domain number. |
| number | Specifies a number between 0 and 255. |
The default ESRP priority is 0.
The ESRP priority is one of the factors used by the ESRP election algorithm in determining which switch is the Master switch.
The range of the priority value is 0 to 254, with 0 being the lowest priority, 254 being the highest. If the ESRP priority is the determining criteria for the election algorithm, the highest priority value determines which switch acts as master for a particular ESRP domain.
Setting the priority to 255 configures the switch to slave mode, and to be ineligible to become the master. The switch remains in slave mode even when the ESRP domain fails over from the current master. This feature is typically used to ensure a switch cannot become the ESRP master while it is offline for servicing.
The following command configures the ESRP priority to the highest priority on ESRP domain esrp1:
configure esrp esrp1 priority 254
This command was first available in ExtremeXOS 11.0.
