show script output autoexec
Description
Shows the results of executing the autoexec script.
Syntax Description
Default
N/A
Usage Guidelines
Use this command to show results when a autoexec.xsf file is executed. The file is not executed when a default.xsf file has been executed.
The CLI script file autoexec.xsf is executed after the configuration has been loaded. Its purpose is to run some commands after every reboot. It can also be used to revert to the original configuration following changes made by UPM executed persistent commands.
This command shows the results of executing the autoexec script:
When there is no autoexec.xsf file, there is no response.
Platform Availability
