Configures the delay between two consecutive DMM/LMM frames.
segment_name |
Alphanumeric string identifying the segment name. |
frame-delay |
Y.1731 Ethernet frame delay measurement. |
frame-loss |
Y.1731 Ethernet frame loss measurement. |
interval |
Trasmit interval in seconds, with a range of 1 to 90. |
N/A.
Configures the delay between two consecutive DMM/LMM frames. The configured delay would be for both continuous and on-demand transmission. This command is optional, and if not configured, the default interval would be 10 seconds.
If the optional keyword frame-delay or frame-loss is not specified, the same value of transmit-interval will be used for both DMM and LMM. The optional keyword allows configuring different values for DMM and LMM.
configure cfm segment cs2 frame-delay transmit-interval 10 configure cfm segment cs2 frame-loss transmit-interval 10
This command was first available in ExtremeXOS 15.1.
