Clears PIM multicast cache table.
ipv4 | Specifies an IPv4 address. |
ipv6 | Specifies an IPv6 address. |
group_addr | Specifies a group address. |
source_addr | Specifies a source IP address. |
If no options are specified, all PIM cache entries are flushed.
This command can be used by network operators to manually remove IPMC software and hardware forwarding cache entries instantly. If the stream is available, caches are re-created; otherwise, caches are removed permanently. This command can disrupt the normal forwarding of multicast traffic.
The following example resets the IP multicast table for group 224.1.2.3:
clear pim cache 224.1.2.3
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
