configure mld snooping leave-timeout
configure mld snooping leave-timeout leave_timeout_ms {{vlan} vlan_name} {{vr} vr_name}
Description
Configures the MLD snooping leave timeout.
Syntax Description
leave_timeout_ms Specifies an MLD leave timeout value in milliseconds upon receiving an MLD done message.
vlan_name Applies the configuration only to the specified VLAN. If no VLAN is specified, the configuration applies to all VLANs.
vr_name Specifies the VR to which the configuration should be applied. If no parameter is specified, the configuration is applied to the current VR context.
Default
1000 ms.
Usage Guidelines
The range is 0–175000 ms (175 seconds). For timeout values of one second or less, you must set the leave-timeout to a multiple of 100 ms. For values of more than one second, you must set the leave-timeout to a multiple of 1000 ms (one second).
The specified time is the maximum leave timeout value. The switch could leave sooner if an MLD done message is received before the timeout occurs.
The following example configures the MLD snooping leave timeout to 10 seconds:
configure mld snooping leave-timeout 10000
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
