Deletes a default blackhole route from the routing table.
| multicast | Specifies a default blackhole multicast route to delete. |
| multicast-only | Specifies a default blackhole multicast route to delete. This option is provided for backward compatibility with releases prior to ExtremeXOS Release 12.1. |
| unicast | Specifies a default blackhole unicast route to delete. |
| unicast-only | Specifies a default blackhole unicast-only route to delete. This option is provided for backward compatibility with releases prior to ExtremeXOS Release 12.1. |
| vrname | Specifies a VR or VRF name. |
If you do not specify a VR or VRF, the current VR context is used.
None.
The following command deletes a blackhole default route from the routing table:
configure iproute delete blackhole default
