Configures the register filter at the Rendezvous Point.
| ipv4 | Specifies the IPv4 address family. |
| ipv6 | Specifies the IPv6 address family. |
| rp_policy_name | Specifies the Policy File for RP Register filter. |
| none | Unconfigures the configured RP Register filter. |
N/A.
Use this command to add or remove a Rendezvous Point Register Filter policy.
The following example configures IPv4 register policy named "entry_policy":
configure pim ipv4 register-policy rp entry_policy
This command was first available in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
