Configures a range of IPv6 addresses in an OSPFv3 area to be aggregated.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| ipv6netmask | Specifies an IPv6 address / prefix length. |
| advertise | Specifies to advertise the aggregated range of IPv6 addresses. |
| noadvert | Specifies not to advertise the aggregated range of IPv6 addresses. |
| inter-prefix | Specifies aggregate, inter-area-prefix LSAs. |
| nssa | NSSA LSAs. |
No OSPFv3 inter-area-prefix LSAs are configured.
If advertised, the aggregated IPv6 range is exported as a single LSA by the ABR.
The following command is used to summarize a certain range of IPv6 addresses within an area and export them out as a single address to area 0.0.0.1:
configure ospfv3 area 0.0.0.1 add range 2aaa:456:3ffe::/64 advertise inter-prefix
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
