Deletes SNMPv3 target addresses.
| hex_addr_name | Specifies an identifier for the target address. The value is to be supplied as a colon separated string of hex octets. |
| addr_name | Specifies a string identifier for the target address. |
| all | Specifies all target addresses. |
N/A.
Use this command to delete an entry in the SNMPv3 snmpTargetAddressTable.
The following command deletes target address named A1:
configure snmpv3 delete target-addr A1
The hex_addr_name parameter was added in ExtremeXOS 11.0.
