Configures the interval for which loop protect events are counted by the loop protect event threshold.
| stpd_name | Specifies an STPD name on the switch. |
| interval | The length of the interval, in seconds, over which the loop protect event threshold is defined. The valid range is 0–255 seconds. |
By default the interval is set to 180 seconds.
None.
The following example sets the loop protect event window to 120 seconds for STP domain r1.
configure stpd r1 loop-protect event-window 120
This command was first available in ExtremeXOS 15.7.1.
