Disables the use of ELRP by ESRP in the pre-master state.
| esrpDomain | Specifies an ESRP domain name. |
Disabled.
Use this command to disable the use of ELRP by ESRP in the pre-master state. When you disable ELRP in the pre-master state, the ESRP pre-master switch no longer transmits ELRP PDUs to detect network loops prior to changing to the master state.
The following command disables the use of ELRP in the pre-master state on the ESRP domain elrp1:
configure esrp elrp1 esrp elrp-premaster poll disable
This command was first available in ExtremeXOS 11.1.
