Adds a member VLAN to an ESRP domain.
| esrpDomain | Specifies the name of an ESRP domain. |
| vlan_name | Specifies the name of the member VLAN. |
N/A.
You can configure zero or more member VLANs for each ESRP domain. An ESRP domain contains one master and zero or more member VLANs.
Master VLANs can have their own set of ports, and member VLANs can have a different set of ports. The state of the ESRP device determines whether the ports in the master and member VLANs are in the forwarding or blocking state.
The following command adds VLAN green to the ESRP domain esrp1 as a member VLAN:
configure esrp esrp1 add member vlan green
This command was first available in ExtremeXOS 11.0.
