Disables the Domain Name System (DNS) cache on a virtual router (VR) or VLAN.
| dns | Domain name system. |
| cache | Specifies disabling the DNS cache. |
| vlan | Specifies disabling DNS cache on a VLAN. |
| vlan_name | Specifies the VLAN name. |
| vr | Specifies disabling DNS cache on a VR. |
| vr_name | Specifies the VR name. If not specified, the VR of the current command context is used. |
If no VR name is specified, the VR of the current command context is used.
To view the DNS cache configuration, use the command show dns cache configuration {{vlan} vlan_name | {vr} vr_name}
The following example disables DNS cache on VLAN "VLAN1":
# disable dns cache vlan VLAN1
This command was first available in ExtremeXOS 30.3.
