Disables jumbo frame support on a port.
all |
Specifies all ports. |
port_list |
Specifies one or more ports or slots and ports. |
Disabled.
Use this command to disable jumbo frames on individual ports.
The following command disables jumbo frame support on a switch:
disable jumbo-frame ports all
