Deletes a tracking entry for the specified route.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID of the target VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| ipaddress |
Specifies the IPv4 or IPv6 prefix of the route. |
| masklength |
Specifies the length of the route's prefix. |
N/A.
Deleting a tracking entry while VRRP is enabled causes the VRRP VRs state to be re-evaluated for failover.
The following command disables tracking of routes to the specified subnet for VLAN vlan-1:
configure vrrp vlan vlan-1 vrid 1 delete track-iproute 3.1.0.0/24
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
