Clears the counters associated with EDP.
| ports | Specifies one or more ports or slots and ports. |
If you do not specify a port, the EDP counters will be cleared for all ports.
Switch PDUs transmitted.
VLAN PDUs transmitted.
Transmit PDUs with errors.
Switch PDUs received.
VLAN PDUs received.
Received PDUs with errors.
The following command clears the EDP counters on all ports:
clear counters edp
