Enables OSPF on one or all VLANs (router interfaces).
| vlan-name | Specifies a VLAN name. |
| all | Specifies all VLANs. |
| area-identifier | Specifies the area to which the VLAN is assigned. |
| passive | Specifies to stop sending and receiving hello packets on this interface. |
Disabled.
Not applicable.
The following command enables OSPF on a VLAN named accounting:
configure ospf add vlan accounting area 0.0.0.1
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
