Shows policy resource settings and usage for currently set profile, or optionally shows the potential resource setting for a specified, different profile.
| default | Shows potential policy resource settings if configuring default profile. |
| less-acl | Shows potential policy resource settings if configuring profile that removes some access list resources to be used for rules. |
| more-ipv4 | Shows potential policy resource settings if configuring profile that adds IPv4 rules. |
| more-ipv4-no-ipv6 | Shows potential policy resource settings if configuring profile that adds IPv4 rules and removes IPv6 rules. |
| more-ipv4-no-l2 | Shows potential policy resource settings if configuring profile that adds IPv4 rules and removes L2 rules. |
| more-mac-no-ipv6 | Shows potential policy resource settings if configuring profile that adds MAC rules and removes IPv6 rules. |
| more-ipv4-no-mac-no-ipv6-no-l2 | Shows potential policy resource settings if configuring profile that adds IPv4 rules and removes MAC, IPv6, and L2 rules. |
| more-ipv4-no-mac-no-ipv6 | Shows potential policy resource settings if configuring profile that adds IPv4 rules and removes MAC and IPv6 rules. |
| profile-modifier | Shows potential policy resource settings if configuring a profile-modifier. |
| no-mac | Shows potential policy resource settings if configuring a profile-modifier that removes all MAC rules. |
| no-ipv4 | Shows potential policy resource settings if configuring a profile-modifier that removes all IPv4 rules. |
| no-ipv6 | Shows potential policy resource settings if configuring a profile-modifier that removes all IPv6 rules. |
| no-l2 | Shows potential policy resource settings if configuring a profile-modifier that removes all L2 rules. |
None.
Pressing ENTER rather than selecting any options for the command shows the current resource profile settings.
The following example shows the current resource profile settings:
# show policy resource-profile
Current Configured Profile: default
Current Profile Modifier : no-l2
MAC IPv6 IPv4 L2
Rules Rules Rules Rules
Max 512 512 440 0
Used 0 0 0 0
L2 ether rules are accounted for in the IPv4 group
show policy resource-profile more-mac-no-ipv6
MAC IPv6 IPv4 L2
Slot Rules Rules Rules Rules Type
1 512 0 256 184 model name
2 512 0 256 184 model name
3 512 0 256 184 model name
4 0 0 256 184 model name
Max 0 0 256 184 (Stack)
Used 3 1 5 0 (Stack)
Max : This row shows the maximum resources available for the stack
if the specified profile is chosen.
MAC IPv6 IPv4 L2
1 0 0 256 184 model name
Max 0 0 256 184 (Switch)
Used 1 0 3 0 (Switch)
Max : This row shows the maximum resources available for the switch
This command was first available in ExtremeXOS 22.1.
Profile modification information was added in ExtremeXOS 22.4.
Additional profiles (no-l2) and profile modifier were added in ExtremeXOS 30.2.
