Configures a profile that controls the policy rule resources available for MAC/IPv4/IPv6/L2.
| default | Configure a profile with the default settings. |
| less-acl | Configure a profile that removes some access list resources to be used for rules. |
| more-ipv4 | Configure a profile that adds IPv4 rules. |
| more-ipv4-no-ipv6 | Configure a profile that adds IPv4 rules at the expense of IPv6 rules. |
| more-ipv4-no-l2 | Configure a profile that adds IPv4 rules at the expense of L2 rules. L2 ether rules are accounted for in the first available space from IPv4, IPv6, or MAC group. |
| more-ipv4-no-mac-no-ipv6 | Configure a profile that adds IPv4 rules at the expense of MAC and IPv6 rules |
| more-ipv4-no-mac-no-ipv6-no-l2 | Configure a profile that adds IPv4 rules at the expense of MAC, IPv6, and L2 rules. L2 ether rules are accounted for in the IPv4 group. |
| more-mac-no-ipv6 | Configure a profile that adds MAC rules at the expense of IPv6 rules. |
| profile-modifier | Specifies modifying the current profile settings. |
| no-mac | Specifies modifying the current profile, which removes all MAC rules. |
| no_mac | Specifies removing all MAC rules: "enable" or "disable" (default is disabled). |
| no-ipv4 | Specifies modifying the current profile, which removes all IPv4 rules. |
| no_ipv4 | Specifies removing all IPv4 rules: "enable" or "disable" (default is disabled). |
| no-ipv6 | Specifies modifying the current profile, which removes all IPv6 rules. |
| no_ipv6 | Specifies removing all IPv6 rules: "enable" or "disable" (default is disabled). |
| no-l2 | Modify the current profile that removes all L2 rules. L2 ether rules are accounted for in the first available space from IPv4, IPv6, or MAC group. |
| no_l2 | Modifier that removes all L2 rules: enable or disable (default is disabled). |
By default, the profile modifier is none.
By default, the profile modifier no-l2 is disabled.
You cannot configure the system to use a new resource profiles while policy is enabled. You must disable policy first.
Current IPv6 rule usage 1 is higher than max value 0 supplied by profile more-mac-no-ipv6
configure policy resource-profile more-ipv4-no-ipv6
This command was first available in ExtremeXOS 22.1.
Profile modification ability was added in ExtremeXOS 22.4.
The profiles more-ipv4-no-mac-no-ipv6 and less-acl-more-ipv4-no-mac-no-ipv6 were added in ExtremeXOS 22.4.
The profiles more-ipv4-no-l2 and more-ipv4-no-mac-no-ipv6-no-l2, and profile modifier no-l2 were added in ExtremeXOS 30.2.
