This command configures the class of service for a particular cfm segment. This value is used to fill the dot1p priority bit in the Ethernet header during transmission.
If the optional keyword frame-delay is not specified, the same value of Dot1p will be used for both DMM and LMM. The optional keyword allows configuring different values for DMM and LMM.
segment_name |
An alpha numeric string identifying the segment name. |
dot1p_priority |
Priority value that is set in the DMM/DMR. The range is 0 to 7. |
N/A.
Use this command to configure the class of service for a particular cfm segment.
configure cfm segment frame-delay dot1p 4
This command was first available in ExtremeXOS 12.3.
