Configures the system date and time.
| month | Specifies the month. The range is 1-12. |
| day | Specifies the day of the month. The range is 1-31. |
| year | Specifies the year in the YYYY format.The range is 2003 to 2036. |
| hour | Specifies the hour of the day. The range is 0 (midnight) to 23 (11 pm). |
| min | Specifies the minute. The range is 0-59. |
| sec | Specifies the second. The range is 0-59. |
N/A.
The format for the system date and time is as follows:
mm dd yyyy hh mm ss
The time uses a 24-hour clock format. You cannot set the year earlier than 2003 or past 2036. You have the choice of inputting the entire time/date string. If you provide one item at a time and press [Tab], the screen prompts you for the next item. Press [cr] to complete the input.
The following command configures a system date of February 15, 2002 and a system time of 8:42 AM and 55 seconds:
configure time 02 15 2002 08 42 55
