Disables all or part of selective forwarding by deleting ports from the ESRP-aware port list.
| domain | Specifies an ESRP domain name. |
| all | Specifies that all of the ports are to be disabled. |
| port_list | Specifies the ports to be disabled from the ESRP-aware port list. |
| group number | Specifies the ESRP group within the given domain name |
The group number defaults to '0'.
By configuring selective forwarding, you create an ESRP-aware port list of only those ports that forward to the ESRP groups that are associated with an ESRP-aware VLAN. That port list is used for forwarding ESRP PDUs from the selected ports only of an ESRP-aware switch.
Use this command to delete one or more or all of the ports from an ESRP-aware port list. Deleting all of the ports puts the domain back to the default state.
The following command configures esrp domain (d1) to exclude ESRP PDUs on ports 5:1, 5:2, and 6:2.
configure esrp d1 aware delete selective-forward-ports 5:1,5:2,6:2 group 0
This command was first available in Extreme XOS 12.0.
