Adds a dynamic ACL rule for the specified role and specifies the order.
| role_name |
Specifies the name of an existing role. |
| rule_name |
Specifies the name of a dynamic ACL rule to add to the specified role. |
The order of the dynamic rule is last if the order is not explicitly specified.
The maximum number of policies or ACL rules that can be applied to a particular role is restricted to 8. This count does not include the policies and rules inherited from a parent role. Since the maximum hierarchy depth is 5, the maximum number of policies and rules supported for a role at the maximum hierarchy depth is 40 (8 x 5).
When a dynamic ACL rule is added to a role, it is immediately installed for all identities mapped to that role and roles below it in the role hierarchy.
The following example configures the role named India-Engr to use the ACL rule named india-Engr-rule:
* Switch.55 # configure identity-management role "India-Engr" add dynamic-rule india-Engr-rule
This command was first available in ExtremeXOS 12.5.
This command was modified in ExtremeXOS 15.2.1 to specify order.
