Enables and disables snooping of IPv6 prefixes delegated via DHCP.
| on | Enables snooping of IPv6 prefixes delegated via DHCP on the specified VLAN. |
| vlan_name | Specifies the VLAN. |
| off | Disables snooping of IPv6 prefixes delegated via DHCP on the specified VLAN. |
| vlan all | Disables snooping of IPv6 prefixes delegated via DHCP on all VLANs. |
By default, snooping of IPv6 prefixes is off.
You can enable snooping on a specific VLAN.
You can disable the snooping on a specific VLAN or all VLANs.
The following example disables snooping of IPv6 prefixes on all VLANs.
configure bootprelay ipv6 prefix-delegation snooping off vlan all
This command was first available in ExtremeXOS 15.7.1.
