Displays the authentication failure VLAN related configuration details.
| vlan_name | Specifies the name of a failure VLAN. |
| vlan_list | Specifies the failure VLAN list of IDs. |
N/A.
Use this command to display configuration details for the authentication failure VLAN.
The following is sample output from this command:
# show netlogin authentication failure vlan ------------------------------------------------------------------------------ Authentication Service unavailable Vlan port Status ------------------------------------------------------------------------------ corp 1:2 Disabled
The vlan_list variable was added in ExtremeXOS 16.1.
