Enable the ability of ERPS to set the topology-change bit to send out Flush events.
| ring-name | Alphanumeric string that identifies the ERPS sub-ring. |
| topology-change | Topology change propagation control. |
N/A.
Use this command to enable the ability of ERPS to set the topology-change bit to send out Flush events.
The following example enables the ability to set the topology-change bit for an existing ERPS sub-ring identified as “ring1”:
enable erps ring1 topology-change
This command was first available in ExtremeXOS 15.1.
This command is available on all platforms supported in 12.6 and forward that are running ExtremeXOS.
