configure keychain delete key
configure keychain keychain_name delete key key_id
Description
This command deletes a key to add to a keychain.
Syntax Description
keychain_name Specifies the name of the keychain.
delete Specifies deleting a key from the keychain.
key Authentication key entry.
key_id Specifies the unique identifier within a keychain. Range is 1-65535.
Default
N/A
Usage Guidelines
Use this command to delete a key from a configured keychain.
The following command deleetes a key:
configure keychain ospfv3-keys1 delete key 3
This command was first available in ExtremeXOS 31.3.
Platform Availability
