Deletes a previously created connectivity-association (CA) object that holds MAC Security (MACsec) key authentication data.
| connectivity-association | Secures connectivity provided between MACsec stations. |
| ca_name | Selects the CA to delete. |
N/A.
Prior to deletion, ports assigned to the CA must be removed with the configure macsec connectivity-association ca_name [pre-shared-key {ckn ckn} {cak [encrypted encrypted_cak] | cak} | ports [port_list] [enable | disable]] command using the disable option.
# delete macsec connectivity-association testca
This command was first available in ExtremeXOS 30.1.
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.| Platform | Ports |
| ExtremeSwitching 5320 | All ports of all models except stacking ports. |
| ExtremeSwitching 5420 | All ports of all models except stacking ports. |
| ExtremeSwitching 5520 | All ports, except 5520-VIM-4X and 5520-24X 10G ports |
| ExtremeSwitching 5720 | All ports of all models except stacking ports. |
| Extreme 7520-48YE-8CE | All front-panel ports. |
