Enables checking if the ARP request source IP address is within the range of the local interface or VLAN domain.
| vr_name | Specifies a VR or VRF. |
Enabled.
If you do not specify a VR or VRF, the command applies to the current VR context.
The following example enables IP ARP checking:
enable iparp checking
The vr option was added in ExtremeXOS 11.0.
