Configures the IP address of a point-to-point neighbor.
| vlan-name | Specifies a VLAN name. |
| ip-address | Specifies an IP address. |
N/A.
None.
The following command configures the IP address of a point-to-point neighbor:
configure ospf vlan accounting neighbor add 10.0.0.1
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
