Enables the identity management feature, which tracks users and devices that connect to the switch.
Disabled.
Only admin-level users can execute this command.
After identity management is enabled, the software creates two dynamic ACL rules named idm_black_list and idm_white_list. These rules are removed if identity management is disabled.
FDB entries are flushed on identity management enabled ports when this command is executed.
The following command enables the identity management feature:
enable identity-management
This command was first available in ExtremeXOS 12.4.
