Removes the configuration for one or both NMS servers.
| primary | secondary | Specifies the whether you are unconfiguring the primary or secondary NMS. |
N/A.
If you do not specify primary or secondary, this command removes the configuration for both NMS servers.
The following command removes the configuration for the secondary NMS server:
# unconfigure vm-tracking nms server secondary
This command was first available in ExtremeXOS 12.5.
