Specifies the remote Syslog server certificate reference identifier.
| all | All specified targets. |
| ipaddress | Specifies the remote Syslog server IPv4 or IPv6 address. |
| tls-port | Specifies using a remote Syslog server Transport Layer Security (TLS) port. |
| tls_port | Specifies the remote Syslog server Transport Layer Security (TLS) port (default is 6514). |
| vr | Specifies a virtual router. |
| vr_name | Specifies the virtual router ID. |
| local | Specifies the remote Syslog server facility: "local0" "local1" "local2" "local3" "local4" "local5" "local6" "local7". |
| reference-identifier | Remote Syslog server certificate reference identifier. |
| reference_identifier | Identifier value (for example, the host name). If none is specified, the existing reference identifier configuration is removed. |
If a TLS port is not specified, the default is 6514.
The following example specifies the reference identifier as "hostname" for all specified targets on VR "vr1":
# configure syslog all vr vr1 reference-identifier hostname
This command was first available in ExtremeXOS 22.3.
