Enables redistribution of routes between OSPF instances.
| vr | Specifies Virtual Router. |
| vr-name | Specifies the source Virtual Router for exported routes. |
| route-type | Specifies the OSPF inter-VR export route type. |
| policy-map | Specifies the route map. |
| cost | Specifies cost. |
| cost | Specifies the cost metric. Range is 0-65535. |
| type | Specifies route type. |
| ase-type-1 | Specifies AS-external type 1 routes. |
| ase-type-2 | Specifies AS-external type 2 routes. |
| tag | Specifies a tag. |
| number | Specifies a tag value. |
| exclude-private | Specifies to exclude routes corresponding to private IP ranges. Default is include private. |
N/A
This command is executed in the destination VR and specifies the source VR.
The exclude-private option excludes prefixes in the private IP address ranges. Only OSPF route types can be exported between instances.
The following command enables OSPF ??:
enable ospf export vr cost 1 ase-type-1 tag 0
This command was first available in ExtremeXOS 32.3.
