Delete a control VLAN on the ERPS ring.
| ring-name | Alphanumeric string that identifies the ERPS ring. |
| vlan_name | Alphanumeric string identifying the VLAN used for control traffic. |
N/A.
Use this command to delete a control VLAN from the ERPS ring. This is the VLAN that carries ERPS control traffic.
Other VLAN types such as VMAN, SVLAN, CVLAN and BVLAN will not be used for control traffic.
A control VLAN cannot be deleted from a ring that has CFM configured.
The following command deletes a control VLAN named “vlan10” from an ERPS ring named “ring1”:
configure erps ring1 delete control vlan vlan10
This command was first available in ExtremeXOS 15.1.
