create mpls static lsp
create mpls static lsp lsp_name destination ipaddress
Description
Creates internal resources for a static LSP and assigns a name to the LSP.
Syntax Description
lsp_name Identifies the LSP to be created.
ipaddress Specifies the endpoint of the LSP.
Default
N/A.
Usage Guidelines
An LSP name must begin with an alphabetical character and may contain alphanumeric characters and underscores (_), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For name creation guidelines and a list of reserved names, see Object Names in the Switch Engine v33.1.1 User Guide .
The following command creates a static LSP:
create mpls static lsp lsp598 destination 11.100.100.8
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
