This command displays information about neighbors and their adjacencies.
| area_name | Specifies a router process for which to specify neighbor information. If you do not specify an IS-IS area, the software displays the neighbors in all areas. |
| vlan_name | Specifies a VLAN for which to specify neighbor information. |
| ipv4 | Displays only the neighbors that advertise the IPv4 protocol as supported. |
| ipv6 | Displays only the neighbors that advertise the IPv6 protocol as supported. |
| detail | Displays detailed information for IS-IS neighbors. |
N/A.
If you do not specify either the ipv4 or the ipv6 keyword, this command displays all neighbors regardless of the supported protocol.
The following command displays IS-IS neighbor information for areax:
show isis neighbors area areax
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
