In an Extended Edge Switching topology, allows the bridge port extender (BPE) slot assignment to be applied to an This command is available on all Universal switches supported in this document. identifier on the specified MLAG peer when the port connected to the BPE is physically connected to the MLAG peer switch.
| vpex | Specifies Virtual Port Extender (VPEX). |
| mlag-id | Specifies setting a unique MLAG identifier of the MLAG port attached to the bridge port extender (BPE). |
| mlag_id | Sets the MLAG identifier value of the MLAG port attached to the BPE. Range is 1–65,000. |
| peer | Specifies naming the MLAG peer switch. |
| peer_name | Name of the MLAG peer switch. |
| slot | Specifies configuring the slot identifier for the attached BPE. |
| slot_num | Specifies the BPE slot number. Range is 100–162. |
N/A
An Extended Edge Switching topology allows the BPE slot assignment to be applied to an MLAG identifier on the specified MLAG peer when the port connected to the BPE is physically connected to the MLAG peer switch.
The same Extended Edge Switching slot number must have been declared on the MLAG peer that has a port in the MLAG. On the peer with the MLAG port, either this form of the command can be used, or the traditional form where a controlling bridge port is related to a slot number.
# configure vpex mlag-id 11 peer cb2 slot 100
This command was first available in ExtremeXOS 22.7.
This command is available on ExtremeSwitching 5420 and 5520 series switches, and Extreme 7520-48Y switches.
