Unconfigures an This command is available on all Universal switches supported in this document. peer switch IP address from an MLAG structure.
peer_name |
Specifies an alpha numeric string identifying the MLAG peer. |
N/A.
Use this command to disassociate an MLAG peer structure with an MLAG peer switch IP address.
The following command disassociates the MLAG peer structure switch101 with the MLAG peer switch IP address:
# unconfigure mlag peer switch101 ipaddress
This command was first available in ExtremeXOS 12.5.
